par jashn » Dim Jan 06, 2019 9:18 am
Hello,
It's been a while since I think about modifying my 605 to go to oil but, I miss data:
-temperature ideal for the oil in the pump (bosch) for a start
-the oil remaining in them injection lines would not it be a problem for start up in winter?
I am considering modifications in depth of the fuel system
Thank you
jashn
par cool-tech » Dim Jan 06, 2019 11:37 am
605 2,5l en bosch ???????
cool-tech
par Tibo1987 » Dim Jan 06, 2019 5:40 pm
Hi jashn, u may notice few answers this is because 99% of the forum is speaking french.
Concerning your project, is it a Peugeot 605 or a om605 mercedes engine ?
On both case the oïl stuck in the lines is a problem.. That is why we prefer mixing oil with diesel or gasoline or install a double tank systèm
